Pull-up resistor value
jaygatsby
Joined Nov 23, 2011
182
I have 8 CMOS chips running from 5VDC. Normally I would use a 4.7k ohm resistor for a pull-up. However in this configuration these 8 chips all have their not LT pins tied together. I am going to run these to a pull-up connected to the positive rail, and to a button connected to the negative rail. Since there are 8 chips, I'm not sure what to do about the pull-up resistor. For pins like LT, I don't think the datasheet states current for operation. So where do I begin?
Thank you
Adjuster
Joined Dec 26, 2010
2,148
It may help to state exactly what devices these are, and what the LT function does.
Most CMOS inputs take very little continuous current, but putting many in parallel will add capacitance, slowing the rise time. Does switching speed matter?
jaygatsby
Joined Nov 23, 2011
182
ok - they are 7 segment latch/decoder/driver chips and the LT is lamp test. Switching speed doesn't matter to me, I just want it to stay high until the lamp test button is pushed, then I want them to go low.
Thank you
Adjuster
Joined Dec 26, 2010
2,148
Thank you
Unless they have internal pull up or pull down resistor, each input is likely to be a standard CMOS load. The datasheet should mention any such resistors if they exist.
jaygatsby
Joined Nov 23, 2011
182
Thank you for that and I'll look to see if the data sheet mentions this. In the mean time, would you have time to explain what a standard CMOS load is? And would I multiply that load by the number of chips (8 in my case) when determining the resistor?
Thanks
Adjuster
Joined Dec 26, 2010
2,148
Does the switch or relay need a "wetting current"? If not, 1k would seem quite low enough. 4k7 could give you 40mV error maybe, but would it matter?
30,807
The input currents of CMOS inputs are so low that it doesn't matter what you choose. You need to calculate how much current you wish the switch to sink when the switch is closed. For a 5V supply, 1K would supply 5mA, and 5K would be 1mA.
In practice, anything from 1K to 100K will work fine. It does not matter how many inputs are tied to the one pullup because the input currents are so small. This is not true for TTL gates.
