Hello all,
I'm working on a small 12v circuit that I'd like to reduce the current flow of using an in-line resistor. My question is, am I calculating the needed resistance correctly?
The load is a 150w ceramic PTC heater with a small fan. Here is a link to the Amazon listing https://www.amazon.com/Maxmartt-Temperature-Incubator-Humidifier-Conditioning/dp/B081197DGH
By my calculations, at 13.8v, the current should be 10.9 amps. I plan on running two of these heaters which would be 21.8 amps. I'd like to reduce that to 20 amps due to the relay I'll be using.
Would something like a 0.050 ohm resistor accomplish this?
Thanks in advance,
Robert
Thanks in advance,
Robert
