PT100 with 2 controllers
keykenzo
Joined Aug 12, 2023
I have to options: use PT100 with "HX5135T accuracy thermometer" or "MAX31865" with arduino controller. I want to use the both options.
The question is: It is possible to use one PT100 for both controllers ?
Picbuster
Joined Dec 2, 2013
1,062
depending on;
1: input impedance amp's Pt100 100 Ohm it's class define accuracy
2: 2,3 or 4 wire connection
3: reference voltage source
4: in a bridge or not.
An other option is to build a pre amp circuit to feed both systems.
Picbuster
