PSU with battery backup
cyberaxcess
Joined Nov 13, 2019
I am in need of a circuit to power a raspberry pi, that should include a battery backup so it can run for a few hours if mains power fails.
I have come up with the attached circuit, which includes:
- My testing shows the raspberry pi uses on average around 800ma, peaks to around 950ma.
- 6v sealed lead acid battery (4ah or 7ah) (selected for cost, power requirements).
- charger limited to around 600ma.
- battery monitor to provide a level indicator, stop the charging when sufficient level reached, and cut-off the battery if low voltage reached.
- buck-boost to provide the final 5v to the raspberry pi (buck-boost due to the various possible supply voltages dipping below or close to 5v).
I would appreciate any pointers if I am on the right track and if this will work as expected?
I will probably add a trigger to the raspberry pi (via transistor or optocoupler) to let it know when a low battery voltage is reached so it can shut itself down.
I am concerned around the different possible voltages coming from the power supply and battery, where they meet up. Is this a correct way of doing it (don't want to use a relay to switch between them if I can help it).
Lastly, I am struggling with the buck-boost circuit. I have done some testing with a cheap Chinese board, but would prefer to end up with my own circuit eventually. Any suggestions or pointers to a proper sample circuit I can start with?
Thanks!
Alan
Alec_t
Joined Sep 17, 2013
15,117
Welcome to AAC!
I am concerned around the different possible voltages coming from the power supply and battery, where they meet up. Is this a correct way of doing it?
A diode-OR arrangement, such as you show, is a standard way of connectng two supplies.
Dodgydave
Joined Jun 22, 2012
11,395
Looks good, diodes will separate the 5v and 12v supplies,, better to use a ready made buck booster, Sla batteries charge at a Constant Voltage, so the current will drop as the battery is full, Shotkley diodes are better for low voltage drops,.
cyberaxcess
Joined Nov 13, 2019
Welcome to AAC!
Thank you!
Thanks, I shall build it and see how it all works out :cool:
