PSU noise measurement and thermal noise
kubeek
Joined Sep 20, 2005
5,796
I am buliding a device with 24bit ADC, and would like to be able to measure the noise level on the analog supply rails. For this I want to build a low noise preamp to be able to better feed the signal into a spectrum analyser.
Here is the general layout of the first stage, and my question is, how much does the thermal noise of R3 contribute?
Or more to the point, am I correct to think that the impedance of the noise contributed by R3 is 10k and therefore this noise will be attenuated by the impedance of the capacitor? (assuming the impedance of the measured signal to be 0 ohms)
OBW0549
Joined Mar 2, 2015
3,565
The noise voltage density of a 1 kΩ resistor is about 4 nV/√Hz, so the noise density of a 10 kΩ resistor would be √10 times that, or ≈13 nV/√Hz.
Yes. For frequencies above (1/2 * pi * R * C) ≈ 16 Hz, the capacitor will tend to shunt away the resistor's noise. The effective noise bandwidth of a 1-pole RC filter is about 1.57 times the filter cutoff frequency, or 16 Hz * 1.57 ≈ 25 Hz.
Since the bandwidth is 25 Hz, and the noise density of the resistor is 13 nV/√Hz, the net RMS noise will be
13 nV/√Hz * √25 Hz = 13 nV * 5 = 65 nV rms.
Hymie
Joined Mar 30, 2018
1,347
I assume that your circuit resistors R1 & R2 should be 10kΩ & 90kΩ respectively.
Noise from these components needs to be considered as well as the op-amp (8nV√Hz – typical).
You might find that your circuit is introducing more noise than is on the supply rails.
Why would a scope trace (on mV/div scale) not be adequate to indicate the noise levels?
Why do you require knowing the frequency-domain of the noise?
danadak
Joined Mar 10, 2018
4,057
If you have a DSO set it to infinite persistence and look at supply rails. This will
give you pk-pk noise.
Most spectrum analyzers have low noise preamps in their frontend. What model/
manufacturer do you have.
Regards, Dana.
38,909
Interestingly, the noise in in RC circuit is independent of the resistor value and depends only on the value of the capacitor and the temperature (often called kt/C noise).
The voltage noise is:
For a 1μF at room temperature, this gives vn = 64nV, essentially the same value as OBW0549 calculated by a different method.
Tesla23
Joined May 10, 2009
560
I don't know how low a noise level you want, maybe you don't need that much as many power supply rails are pretty noisy. Others have given you good advice, but the choice of op amp is also critical. There is also a trade-off in the input impedance and noise level. If you are measuring power rail noise then the input impedance is not critical.
The OP1177 is pretty noisy (8nV/√Hz), there are much better options e.g. the ADA4898 has 0.9nV/√Hz.
http://www.analog.com/media/en/technical-documentation/data-sheets/ADA4898-1_4898-2.pdf
The datasheet also gives details of how to make a gain stage with low noise (i.e. discusses resistor values).
The LT1028 is similar, and the datasheet also has lots of useful info:
http://www.analog.com/media/en/technical-documentation/data-sheets/1028fd.pdf
If you want to go even lower, there is Charles Wenzel's design:
http://www.wenzel.com/wp-content/uploads/lowamp.pdf
which he claims is 0.6nV/√Hz
kubeek
Joined Sep 20, 2005
5,796
Why would that be? The power supply in question will have a first stage of an isolated buck converter at around 800kHz, where I measured roughly 100mV pk-pk. After this I plan a linear regulator down to 5V for the analog rail. This I expect to be at least an order of magnitude lower noise, but that would most likely be beyond the capabilities of the instrumenst I have available, definitely for the scopes. I was thinking about the spectrum analyzer beacuse it should have lower noise than a scope, I don´t really need to see frequency domain.
I am not sure how much noise exactly I can tolerate, but the ADC ADS1257 has PSRR of 60dB, so with 5V full scale measured signal I need the noise at around 300uV to be at the 24th bit. Is that correct?
The required precision will be more like 18-19 bits, so the noise needs to be less than 10-20mV?
The opamp I have samples of comes from TI´s appnote http://www.ti.com/lit/ug/tidu016/tidu016.pdf and is OPA211 with 1.1 nV/√Hz at 1 kHz.
