ps2 keyboard signal
Alex1700
Joined Jan 12, 2020
107
Hi all,
I am using the hantek DSO5102P oscilloscope and I find that I am not able to measure the clock and data signal of the ps2 keyboard like ben eater's result
may i know what happen to my scope ?
WBahn
Joined Mar 31, 2012
33,263
Are you supplying power?
It looks like you might be zoomed so far out that the you can't display the signals. The PS/2 data rate is about 10 kbps, so each bit lasts about 0.1 ms. It looks like you scope is set for 40 ms/div (if I'm reading the display correctly), so one bit constitutes 1/400th of one division on your display.
