Please see the grounding scheme below. I would like to prevent electric shock. In the picture everything is referenced to the chassis. The AC inlet has the earth ground connected to chassis. However, the Analog ground (after AC-DC conversion) has it's ground connected to chassis too.
The chassis is then not protective earth but a functional ground, correct?
Is the transformer still isolating?
What is the proper way to ground this type of system? Should only the earth ground be connected to the chassis?
Thanks for any helpful advice!
