Protection Circuits for Input and Outputs on a PCB
DJ_AA
Joined Aug 6, 2021
490
Hi
I am working on a PCB and would like to know if additional protection would be necessary for all my input and output ports.
All the ports eventually connect to a GPIO on my microcontroller.
These circuits that drive the ports.
Output port type 1
H-Bridge driver
Output port type 2
This is a load switch controlling 5V power to an external source or a relay, etc. The DC-DC that produces the 5V is rated to max 300mA
Input Port type 1
This input port use for external open-drain based signal outputs.
Irving
Joined Jan 30, 2016
5,139
Why are you making it so complicated? What are you trying to protect against?
The DRV8837 is an H-Bridge motor driver not an H-Bridge driver, the H & L designations make no sense. What are you trying to do with it?
A relay is, by definition, a galvanically-isolated output device... it needs no further 'protection' and a DC-DC converter is massive overkill. A simple BJT or 3v logic-level MOSFET driving the relay coil to ground, off the 5v rail, is all that is needed + a back-EMF diode.
The input port for an open drain output just needs a pull-up resistor, a series resistor and two TVS catch diodes. R5 may or may not be needed, depending on pull-up voltage.
Or if you are desperate for more isolation, try this:
DJ_AA
Joined Aug 6, 2021
490
Hi
Generally, the protection is against over-current usage or any external shorts.
The DRV8837 is controlling some latching solenoids.
In regards to the input ports, this is just to give a level of protection, as there could be a possibility the input signal could be 5V.
Irving
Joined Jan 30, 2016
5,139
OK on the DRV8837 - that's a common use case, and makes sense if L & H refer to physical location...
Taking the relay output as an example, are you saying the relay is off board and you're worried about a short on the 5v rail to ground, external to the PCB?
DJ_AA
Joined Aug 6, 2021
490
Yes, a user was connect ito GND in error or relay was to be faulty etc.
For the relay output I have I used a load switch as an additional option if I need power an external circuit with 5V. So it works as signal to a relay or to power any external circuit.
DJ_AA
Joined Aug 6, 2021
490
Great, just to confirm can zener diodes be used or TVS i needed? Can this also protect against if 12V is connected to the input?
