I'm not sure what I'm looking at with the circuit you posted. I don't see any PWM. I see the blue trace going from 0-12, which I assume is supposed to be the PWM (but isn't) and the green trace going from 6 to 9 which I assume is the analog output.
Can you please post your simulation so I can play with it?
You mention you are concerned about precision. I anticipate this circuit will be slow to respond (inaccurate any time not in steady state). That is why I recommended the LTC2645. It will respond instantly.Doing a simple low pass filter will give me 0-12v which will only work if i limit my pwm signal to from 50% - 75% which will severely limit the precision i need(I assume)
