proportional amplifier to control dc valve
mah
Joined Mar 15, 2010
393
i want your ideas to do a circuit that amplify input signal 0-10 V to 5-24 v to control a 24 v proportional dc valve
Mod edit: The Completed Projects Forum is for Completed Projects only. It is meant to allow members to show plans for projects they built so other members can duplicate them if desired. New threads are also automatically moderated per Moderator review for this reason. Your thread does not belong in this forum, and was moved here.
30,759
I would look at using something like the OPA551, it is good for ±30v swing at 300ma so you would need a NPN/PNP push-pull output to drive the valve.
mah
Joined Mar 15, 2010
393
but why should i use this type of opamp? why couldn't use it to drive mosfet that could hold high current instead of opamp?
MikeML
5,444
You didn't look far enough down the page. Apex sells some 3A ones.
In a previous life, I bought hundreds of that type of opamp from Apex.
MikeML
5,444
The normal way of controlling this kind of valve is to drive it with a current that is proportional to the input control voltage, not a voltage proportional to the input.
30,759
That is basically the method I used in #16, in CNC applications where ±10vdc analogue is the source.
Feedback via encoder.
this will operate as a voltage follower. when there is positve output the npn will work and connects +v to the valve then 1A passed and blow up the npn
The circuit shown has been around for a long time used in EDM machines etc.
You can limit the maximum freq by resistor in the collectors if needed, or on the output.
mah
Joined Mar 15, 2010
393
did you see the operation in the link ? i want to do something like this.i don't mind to do it with current but also the valve shouldn't mind
