Greetings AAC people
There is a part of a hobbyproject (which for me is a project on its own) that I would like some input on if someone is interested.
Backround
So the bigger project is one of those rotating POV LED displays. Since I don't want a battery on the spinning thing and cables will tangle I had the idea to try something cordless, and before I buy a premade solution I wanted to give it a try myself.
Aaanyhow...
The actual matter
I had an idea for generating AC through a coil and have tried to simulate it. Turned out to be called an H-Bridge and I use it to drive a "tank" circuit to get a sine wave. I tweaked some values and simulation-wise it seems to be doing what I had in mind (What I had in mind is to this point an AC sine wave of about 800-900mA at 150khz through a coil). Btw I also plan to add diodes to protect the transistors.
The schematic is attached as is the LTSpice file. V1 and V3 output a 5V square wave at 150khz but they are inverse to eachother. V2 is at a constant 12VDC.
Reasoning so far
And here are some questions that float around in my head atm...
Questions
I welcome thoughts and comments to any of the questions, my reasoning, the schematic and my poor abilities of electric design (I however prefer nice suggestions)
Also please ask if some piece of info is missing, thanks in advance
- Christoffer
Backround
Aaanyhow...
The actual matter
Reasoning so far
- Since it is to me highly unlikely that I manage to construct a coil that matches the value it should have, I want to supply the frequency from a uC so that I can tune it sufficiently.
- If I by some magical luck should hit the sweet spot of resonance I wanted to limit the current in the tank circuit part, therefore there are a few resistors there. I have experimented some and ideally I wanted something in series with the inductor or capacitor to dampen the oscillation but this seems to upset the nice waveform. I also didn't want too big resistance at the driving (R7 and R8) of it, just enough to limit supply drain.
- There is still some spiking going on between the transistor pairs with the same input which is no wonder if they both doesn't change immediately.
- Since I atm imagine around 800-900mA it maybe doesn't make sense to have driving stage and powerful MOSFETS, but I thought I'd rather make it a little more reliable and variable in case I need more.
Questions
- Is this a reasonable design?
- What's a good way to limit the oscillations in the tank circuit?
- Christoffer
