Project: "Lynx" 2-way speakers
bloguetronica
Joined Apr 27, 2007
1,544
List of components:
C1 – Capacitor Visaton MKP 10µF;
C2 – Capacitor Visaton MKT 22µF;
C3 – Capacitor Visaton MKP 4.7µF;
C4 – Capacitor Visaton MKP 15µF;
FTE1 – Woofer Visaton SC 13 8 OHM;
FTE2 – Tweeter Visaton SC 10 N 8 OHM;
L1 – Coil Visaton SP 0,68mH 1mm;
L2 – Coil Visaton SP 0,22mH 0,6mm;
L3 – Coil Visaton SP 0,33mH 0,6mm;
R – 8,2Ω wirewound resistor (5% tol., 15W).
Electrical parameters:
- Pnom = 100W
- Ppk = 150W
- R = 7,5Ohm
- Znom = 8Ohm
Audio characteristics:
- Frequency response (-10dB): 32-30000Hz
- Sensitivity (1W/1m): 90dB
Recommended enclosure specifications:
- Type: Ported (3th order quasi-Butterworth alignment)
- Volume: 51.13L
- Recommended duct: Monacor BR-70HP (length: 102mm)
- Resonant frequency (Fb): 38.37Hz
- -3dB frequency (F3): 44.76hz
bertus
Joined Apr 5, 2008
22,937
Are you also planning for drawings of the enclosure?
This would be a good addition to the project.
