Hi everyone,
I am beginning an art project that needs to involve 150 buttons switching 150 LEDs on and off (that means 300 ports in total!). They also all need to be connected to a central or master computer somehow that can know the state of each button or LED (on or off) and also send a signal to switch the LEDs on (overriding the physical button). The central computer is needed because I'd like to create some level of gamification or interactivity with the set of LEDs.
I have done a number of Arduino / Raspberry Pi projects before but not of this scale - I know it is ambitious but would be great to get any suggestions on where to begin. The main challenges I have firstly are the number of LEDs and sensors, but perhaps more so the need for a central computer of sorts.
I have thought of the following options as potential starting points, but haven't looked deep into any of them yet so I don't know if any of them are feasible...
- Using multiple Arduinos controlling a number of LEDs / buttons that are plugged into a web server via ethernet cable, and doing the processing through a web app of sorts.
- Chaining a bunch of Arduinos together with i2c or the RS485 (similar to the option above, but without the server)
- Using lots of shift registers for both the LEDs and the inputs, and doing the processing inside a single Arduino.
- Something else that doesn't use Arduino at all, that has at least 300 i/o ports?
I know this is a quite specific post, but any suggestions or comments on my proposed method would be super helpful!
