project in voltage divider BJT
Status
Not open for further replies.
muad
Joined Dec 18, 2015
6
THE AIM OF THE PROJECT TO GET Ic OF 10mA WITH CLASS A ( STABLE Q-POINT ) .
WHICH VALUES ARE RECOMMENDED TO BE TAKEN TO GET AN Ic of 10mA ?
MikeML
5,444
What transistor? What supply voltage? What temperature range? Why are you shouting? Why isn't this posted in the homework forum?
38,859
Sounds like this is a project that should be in the homework section.
The recommended values are those you calculate to get the desired current and stability in the appropriate circuit configured with your selected transistor.
Since we don't do your homework for you here, this should help get you started.
muad
Joined Dec 18, 2015
6
ok thank you
Status
