Hi guys,
I need some help on how to program the controller for an automatic transfer switch. Not necessarily what code to use, but specifically what STEPS the automatic transfer switch should do.
I.e.
If the power fails for at least 10 seconds, it will turn on the generator and perform a switch.
If the Voltage level dips below a certain level it will perform a switch.
If the Voltage level dips for only a second and then comes back to normal it will NOT perform a switch.
Does anybody know the programming that occurs inside an ATS?
I.e.
