I can not run the simulation and I do not know why, I already downloaded the libraries and append them to a sub file.
That's the problem? LOLHi
There is no ground reference on your circuit. add a connection to ground.
eT
Thanks for the help, but I do not know if you could help me with another problemHi
C2 should be .047uF. "m" is interpreted as "milli".
L1 is specified to be 200mH, is that correct?
The voltage source is 400V pk-pk, is that correct?
eT
Resistor R6 is shorted. remove the wire spanning R6.Thanks for the help, but I do not know if you could help me with another problem
Post the model files for TIC22D and DB3.[QUOTE = "eetech00, post: 1372516, miembro: 208630"] El resistor R6 está en cortocircuito. retire el cable que atraviesa R6.
eT [/ QUOTE]
Mmmmm, Okay, the problem is that in my original circuit, that part of the 2 resistors of 250K is really a 500K potentiometer, but I do not understand that there is not in the simulator, so I've done that resistor array like I understood Engineer, probably I understood badly, do you know how I could correct it?
I could not find the TIC226D library and I had to change the Thyristor to Z00607MA...Post the model files for TIC22D and DB3.
This is correct.In the Diac model, change
R_R1 N02098 TRG 1.462*{Tr}
to read
R_R1 N02098 TRG {1.462*Tr}
This is not required because the names are not significant. The pin order IS significant.In your schematic, label the diac terminals as diac_in and diac_out
See post #10I could not find the TIC226D library and I had to change the Thyristor to Z00607MA...
What a good person you are friend, I do not know how to thank you for all your help and experience.
Thank you very much, everything is going greatSee post #10
eT
by Luke James
by Jake Hertz
by Rushi Patel
