Hi thanks for reading this post,
I am making a DAC for better sound quality for my headphone.
The IS25LQ016 (flash memory) is communicating true SPI flash with the XHRA-2HPA (audio interface processor).
Now I need to program the flash memory. I have the files I need to burn in to the chip. https://hackaday.io/project/19889-untz-usb-audio-dac-headphone-amp (upper two files) One is a configuration file. To use this I downloaded xConfigurator.exe but I can't start the program (A SMD window pops up and disappears instantly). I found a blog (http://www.xcore.com/viewtopic.php?t=4815) describing the same problem, I followed the steps but I get an error on smd.
I found another program called batronix prog-express. this program will start and I can open the file in it so that's good. (but I'm not completely sure if this program will work with the IS25LQ016)
Can I use this program with the CH341A usb flash programmer?
I also need to enable Quad-spi but this is not possible with the CH341A usb flash programmer
Does someone knows a cheap and easy way to enable this?
Thanks for the comments
Kind regards,
Kind regards,
