Problems about SPI mode in MSP430
hutai
Joined Jan 3, 2024
I am using MSP430G2553 and the software Energia. This is the following schematic design for the msp.
Can someone enlighten me what does it mean by "from USCI" in the table above?
The problem is that im trying to configure the SPI Mode for a system (with registers.). my codes is as follow:
but when i connect the pin P1.4. i doesnt show anything on the oscilloscope. but when i remove the BIT4 from the register P1SEL2 like this corresponding line:
it does generate the clock of 1MHz. Based on the configuration ( the first image ), it does refer to SMCLK (sub-main clock) of the msp430. but in this case i would like to configure it to be UCA0CLK. Can someone enlighten me ? did i make some errors in the code ?
35,320
Standard SPI signals are:
MOSI = Master Out Slave In
MISO = Master In Slave Out
SCLK = Serial Clock
/CS = Chip Select
On TI MSP430, the names are changed to:
SIMO = Slave In Master Out
SOMI = Slave Out Master In
UCLK = USART Clock
STE = Slave Transmit Enable
Reference: https://www.ti.com/lit/ug/slau144k/slau144k.pdf
The first thing you have to decide is if your MSP430 will be the bus master or a slave device.
Assuming that your MSP430 is the master interfaced to a single device, then you can use 3-pin mode and ignore STE.
On MSP430G2553 MCU, the pin assignments are:
pin-3 = P1.1 = SIMO
pin-4 = P1.2 = SOMI
pin-6 = P1.4 = UCLK
pin-7 = P1.5 = STE
The next step is to configure the I/O pins for USART operation by configuring PxSEL and PxSEL2 where x refers to the I/O port, P1 in this case.
slau144k - page 341
P1SEL2 and P1SEL are 8-bit registers. Hence you can configure all 8 I/O pins of port P1 at the same time.
We want to select Secondary function by setting bit-1, bit-2 and bit-4 to 1 in both registers.
P1SEL2 |= BIT4 | BIT2 | BIT1;
P1SEL |= BIT4 | BIT2 | BIT1;
Configure STE on P1.5, as you wish for 3-pin or 4-pin operation.
The next step is to configure the UCA0 module for SPI operation.
Have a look at this:
https://www.egr.msu.edu/classes/ece480/capstone/spring15/group12/Grager_Application_Note.pdf
35,320
The question refers to how to set up the direction of pin-6 = P1.4 = UCLK.
"from USCI" refers to how USCI module is configured and operating. For example, in a multi-master network, UCLK has to be in the input mode and is switched to output only when the master device is transmitting.
Read section 16.3 in slau144k.
MikeHutao
Joined Aug 2, 2024
11
SCLK = Serial Clock
/CS = Chip Select
UCLK = USART Clock
pin-3 = P1.1 = SIMO
pin-4 = P1.2 = SOMI
pin-6 = P1.4 = UCLK
pin-7 = P1.5 = STE
slau144k - page 341
actually sir, i think i have done exactly the same
MikeHutao
Joined Aug 2, 2024
11
1724136530756.png i got think kind of wave for the P1.4
