Hello
I'm trying to recycle/repair and old RC car and everything was going fine since last week when I got stuck trying to control the main motor.
What I did is replace the old control board ( I lost the RF remote control ) with an arduino UNO board using bluetooth. I managed to build a battery pack, send commands to the arduino via bluetooth/serial and control the direction servo. To control the servo I build a H bridge circuit that is working fine.
My problem is related with my inability to fully saturate the power transistor i recycled from the old board, it's a NPN transistor ( 2SC2654). First I tried to saturate it with the 5V 100% PWM from the arduino, the tried the 5V power pin (I read that can provide more current than pwd pins, not sure), no luck. Then I tried the 7-7,5V from the battery and the the transistor got more saturated allowing more current from collector to emitter, but not 100%. To fully saturate the transistor I have to connect the gate to 12V to get the motor running at almost 100%.
My first hypothesis is that the arduino doesn't provide enouth current to saturate the power transistor. So, I tried to connect this transistor gate to the emitter of another (KN2222A) transistor, no luck either.
The motor uses 0.8A at 12V when wired directly to the battery and runs perfectly.
I have little electronics background so maybe I'm missing something obvious.
The circuit below is the last attempt to make this work with the two transistors.
Thank you in advance.
