problem with leds in arduino
ericgibbs
Joined Jan 29, 2010
21,557
hi Dabu,
The drive transistors for D9/10 are PNP, so if the Arduino pins D8 and D9 are Low 0v, the transistors are On..
E
ericgibbs
Joined Jan 29, 2010
21,557
hi,
Thats not what you said., you did say you were pulsing them Hi/Low
when i turn on the 7 volt power supply led 9 and 10 are always on
EDIT:
If pins D8 and D9 a switched to +5V and the PNP Emitters are at 5V the transistors should be Off.
Dabu WhiteHacker
Joined Sep 5, 2017
68
hi,
EDIT:
sory i forget the emiiter was not at 5 volt :p
my mistake
ericgibbs
Joined Jan 29, 2010
21,557
Measure the pins D8 and D9 actually are at +5V, if for example the Arduino output was say only 4V the transistors would still be ON.
EDIT:
If the Emitters are at 7V a 5V Base signal will not switch them Off...:rolleyes:
Dabu WhiteHacker
Joined Sep 5, 2017
68
EDIT:
bro that is working awesome
you are best (y) have a nice day :D
