I own an EAGLE license, 7.6.0 Professional, and I've got some issue with clearance. Now I am using a MCU with TQFP-100/PT package, and it has a clearance issue even between its pad. I have tried adjusting the DRU clearance down to even 1mil, but the clearance issue is still the same. I tried also adjusting the Stop Mask down to 1mil also, it is always the same clearance problem with the same thickness, can you help with this issue? thanks a lot
The clearance error width is the same from 1mil to 6mil
