problem with 555 monostable
pheonix992
Joined Jun 23, 2013
21
i found the problem
there is a home device which connected to power with it in the same socket
and when this device turn on the 555 triggered
now any help
tracecom
Joined Apr 16, 2010
3,944
Get the mains voltage off the PCB, place the filter capacitors adjacent to the regulator, and add a .1μF capacitor from pin 1 to pin 8 on the 555.
ScottWang
Joined Aug 23, 2012
7,509
I recheck the circuit, the coil also can be in series with the output of bridge rectifier, and if you need to adding the second coil then you just in series with the GND of the output of bridge rectifier.
ScottWang
Joined Aug 23, 2012
7,509
The capacitors are for the positive voltage and some over the Vcc as 12V, it means that the pulse could be over 12V.
If the pulse are negative or low less 0V then the capacitors maybe useless, and during this time the 555 can be triggered, if we using the coil that it can be isolate the pulse to interfering the right side of the coil, and the right side of the coil will keeping in a stable status.
If you in series the coil as the described on #27 then it will become a LC filter.
ScottWang
Joined Aug 23, 2012
7,509
If you using the inductor as the resistor type, you should care about the current that is the choice at here, and the watt is enough or not, the coil is a choke coil here, against the rush current.
So you can try and to get some Experience.
