Problem while trying to implement an stm32f103c8 UART driver
fadi1999
Joined May 29, 2024
Hye stackoverflow community I am trying to implement a UART driver but I am facing a problem with these codes and I don't know to fix it, I try to simulate the functionality of this driver in Proteus using virtual terminal but I don't receive the data from the terminal when i simulate the code in proteus, so i don't know eighter the problem is in each function? i wish that i can find someone that can tell me how to fix this code :
UART.h :
#ifndef __UART_H__
#define __UART_H__
#include <stdint.h>
#define RCC_BASE 0x40021000
#define GPIOA_BASE 0x40010800
#define GPIOB_BASE 0x40010C00
#define GPIOC_BASE 0x40011400
#define GPIOD_BASE 0x40011800
// APB2 peripheral clock enable register (RCC_APB2ENR) offset
#define RCC_APB2ENR_OFFSET 0x18
// APB1 peripheral clock enable register (RCC_APB1ENR) offset
#define RCC_APB1ENR_OFFSET 0x1C
// peripheral register offsets
#define GPIO_CRL_OFFSET 0x00
#define GPIO_CRH_OFFSET 0x04
#define GPIO_ODR_OFFSET 0x0C
#define USART1_BASE_ADDR 0x40013800
#define USART2_BASE_ADDR 0x40004400
#define USART_CR1_OFFSET 0x00
#define USART_BRR_OFFSET 0x08
#define USART_DR_OFFSET 0x04
#define USART_SR_OFFSET 0x00
#define SystemCoreClock 168000000
void GPIOx_Clock_enable(uint32_t gpio_base);
void uart_enable_clock(uint32_t uart_base);
void uart_configure_baudrate(uint32_t uart_base, uint32_t baud_rate);
void gpio_set_alternate_function(uint32_t gpio_base, uint8_t pin, uint8_t af_mode);
void uart_configure_transfer_direction(uint32_t uart_base, uint8_t tx_enable, uint8_t rx_enable);
void uart_enable_module(uint32_t uart_base);
void uart_transmit_char(uint32_t uart_base, char ch);
void uart_transmit_string(uint32_t uart_base, const char *str);
#endif
UART.c:
#include "UART.h"
void GPIOx_Clock_enable(uint32_t gpio_base){
volatile uint32_t *RCC_APB2ENR = (volatile uint32_t *)(RCC_BASE + RCC_APB2ENR_OFFSET);
switch (gpio_base) {
case GPIOA_BASE:
// code block
*RCC_APB2ENR |= (1U << 2);
break;
case GPIOB_BASE:
// code block
*RCC_APB2ENR |= (1U << 3);
break;
case GPIOC_BASE:
// code block
*RCC_APB2ENR |= (1U << 4);
break;
case GPIOD_BASE:
// code block
*RCC_APB2ENR |= (1U << 5);
break;
default:
// code block
break;
switch (uart_base) {
case USART1_BASE_ADDR:
// code block
volatile uint32_t *rcc_apb2enr = (volatile uint32_t *)(RCC_BASE + RCC_APB2ENR_OFFSET);
*rcc_apb2enr |= 1U << 14;
break;
case USART2_BASE_ADDR:
// code block
volatile uint32_t *rcc_apb1enr = (volatile uint32_t *)(RCC_BASE + RCC_APB1ENR_OFFSET);
*rcc_apb1enr |= 1U << 17;
break;
default:
// code block
break;
volatile uint32_t *usart_brr = (volatile uint32_t *)(uart_base + USART_BRR_OFFSET);
//volatile uint32_t *usart_brr = (volatile uint32_t *)(APB1_PERIPHERAL + USART1_PERIPHERAL_OFFSET + USART_BRR_OFFSET);
// Calculate baud rate divisor and set BRR register
*usart_brr = (SystemCoreClock + (baud_rate/2)) / baud_rate;
volatile uint32_t *gpio_cr;
uint8_t pin_index = pin % 8;
if (pin < 8) {
gpio_cr = (volatile uint32_t *)(gpio_base + GPIO_CRL_OFFSET);
} else {
gpio_cr = (volatile uint32_t *)(gpio_base + GPIO_CRH_OFFSET);
//pin_index = pin - 8;
// Clear pin configuration bits
*gpio_cr &= ~(0xF << (4 * pin_index));
// Set pin mode to alternate function output push-pull
*gpio_cr |= (af_mode << (4 * pin_index));
volatile uint32_t *usart_cr1 = (volatile uint32_t *)(uart_base + USART_CR1_OFFSET);
// Configure USART TX and RX enable bits
if (tx_enable) {
*usart_cr1 |= (1U << 3); // Set TE (Transmitter Enable) bit
} else {
*usart_cr1 &= ~(1U << 3); // Clear TE bit
if (rx_enable) {
*usart_cr1 |= (1U << 2); // Set RE (Receiver Enable) bit
} else {
*usart_cr1 &= ~(1U << 2); // Clear RE bit
// Enable USART module by setting UE (USART Enable) bit
*usart_cr1 |= (1U << 13);
volatile uint32_t *usart_sr = (volatile uint32_t *)(uart_base + USART_SR_OFFSET);
volatile uint32_t *usart_dr = (volatile uint32_t *)(uart_base + USART_DR_OFFSET);
// Wait until transmit data register is empty
while (!(*usart_sr & (1U << 7)));
// Transmit data by writing to data register
*usart_dr |= (ch & 0xFF);
while (*str != '\0') {
uart_transmit_char(uart_base, *str);
str++;
main.c:
#include "UART.h"
int main(void)
GPIOx_Clock_enable(GPIOA_BASE);
uart_enable_clock(USART1_BASE_ADDR);
// Configure USART1 baud rate to 9600
uart_configure_baudrate(USART1_BASE_ADDR, 9600);
// Configure PA9 (USART1 TX) as alternate function output push-pull
gpio_set_alternate_function(GPIOA_BASE, 9, 0b00000010); // AF mode 0b0010 for USART1 TX
// Configure USART1 for TX and RX (enable both)
uart_configure_transfer_direction(USART1_BASE_ADDR, 1, 0);
// Enable USART1 module
uart_enable_module(USART1_BASE_ADDR);
// Send a string over USART1
uart_transmit_string(USART1_BASE_ADDR, "Hello, UART!\r\n");
while (1)
// Main application loop
return 0;
35,180
Your code is too complex to debug. Do simple things, one at a time.
I don’t do Proteus but I can show you how to do it in IAR or in STM32CubeIDE.
fadi1999
Joined May 29, 2024
the code is already commented and divided into sub blocks and sub steps but i think there is an algorithmic step that is missing but i don't know which step i miss.
35,180
You have three separate text files shown. It would be better to keep them separate, for example:
C:
#include "UART.h"
int main(void)
while (1)
return 0;
Use code tags for better viewing and scrolling like this:
[CODE=C]... your code here ...[/CODE]
35,180
What I mean by keeping it simple:
(1) Start by making an LED flash. This would verify that your code for initializing an STM32 peripheral is working.
(2) Send a single character "U" in a loop. If you have an oscilloscope you will be able to confirm the transmission baud.
BobTPH
Joined Jun 5, 2013
11,651
+1
I always start with that. It will hive you a square wave with a gap for the start and stop bits.
A multimeter will show roughly 1/2 the Vdd in the TX pin, and a frequency of a little less than half the baud rate. So you can debug with just a multimeter.
