Problem while implementing a circuit.
Saify
Joined Mar 29, 2019
7
I was working on a servo motor control circuit using variable resister . When I implement the whole circuit on the breadboard, the servo motor was just vibrating instead of working. I use mini servo motor(SG90) but in project diagram SG5010 is used. Is that may cause any problem.
Thank you
this is the project that I'm trying to
bertus
Joined Apr 5, 2008
22,995
From the given page:
A pot can be used to control the position of the servo by using the following circuit.
It produces a positive pulse between about 0.9 milliseconds and 2.1 milliseconds.
The off period between pulses is about 40 milliseconds.
This can be shortened by reducing the value of the 3M3 resistor.
Bertus
Saify
Joined Mar 29, 2019
7
Bertus
Thank you
