OSCCON, in this case, should have no effect on whether or not the LED blinks.Problem solved!! it was OSCCON = 0x60; missing from the code...! i write it and i program again the pic and everything now works!! thank you a lot!!!
Were you recompiling the *.c file each time you programmed the device?
