Problem in PWM Isolation
chirag modesara
Joined Dec 23, 2015
12
my project is isolator which can convert j type thermocouple in 2 channel.
so here i using micocontroller and HCNR200 as a Isolation ic.
but i cant got perfect reading from HNCR200 .
My Pwm is correct.
can anyone tell me where i made mistake.
is that HCNR200 good for PWM isolation??
chirag modesara
Joined Dec 23, 2015
12
Thnks sensacell for fast responce,
find the attached isolation schematic.
i am using +5 and _5 instead of 15 and -15 respectivaly.
and i also change the LT1097 opamp with OP07CP.
microcontroller's Pwm out directly connected to this circuit. and i check the output at right side of this circuit.
AlbertHall
Joined Jun 4, 2014
12,625
So the input to this circuit is PWM direct from a microcontroller - a 0V to 5V square wave?
You say the output is not 'perfect' - what did you expect and what did you actually get?
Sensacell
Joined Jun 19, 2012
3,785
Still have no idea what you are doing, that's just an application schematic from the data sheet.
What are you trying to accomplish?
DickCappels
Joined Aug 21, 2008
10,661
Can you also help us find a datasheet for the HNCR200. I have a suspicion that it was not designed for high speed signalling.
Related to that, what is your PWM clock frequency, the number of bits and the type of PWM waveform (comb or a single pulse per cycle)?
