Problem in proteus 8 simulation using piccolo micocontriller
Muhammed Adel
Joined Feb 15, 2017
i make small project 'blinking lamp' in proteus it runs without error but nothing happens for the lamp . note this project is correctly build and run on the kit.
what are possible problems ?
thanks ,
JohnInTX
Joined Jun 26, 2012
4,787
Welcome to AAC!
From your post, I understand that you have simulated the program in Proteus and it works but when you try it on actual hardware it does not work. Is that correct?
If you could provide more detailed information that would help us to help you:
Which Piccolo kit are you using?
What programming language are you using?
How do you have the kit hooked up? What are you using for a power supply etc?
http://www.ti.com/lsds/ti/microcont...me_control/f2802x_f2803x_f2806x/overview.page
absf
Joined Dec 29, 2010
1,968
When you say 'Lamp' are you refering to the active LED?
The only Lamp I can find is a 12V filament one that needs 12V DC to lite it up. If you use that you need a transistor or relay to drive it or the V and I wouldn't be high enough to light it.
Show us a screen capture of your schematic and simulation....
Allen
