problem creating noise source
mpradhan
Joined Feb 25, 2009
1
Hi I am trying to create or produce noise in my circuit which deals with the design of a lock in detection system. I have already tried using a zener diode in reverse biase mode but did not get any results. Is there any other way of producing noise ? Thanks
Wendy
Joined Mar 24, 2008
23,851
What was the circuit diagram, and what is the low and high frequency cutoffs?
I've always heard you need a lot of gain after a low level noise source, so I have to ask what kind of amplification you used.
KL7AJ
Joined Nov 4, 2008
2,229
It's better to use a dedicated noise diode
http://www.noisecom.com/products_noise_diodes.asp
I've usually been able to get a couple of free samples from these guys.
Eric
bertus
Joined Apr 5, 2008
23,006
What is the frequency range of the noise ?
Is it in audio range or do you need RF noise ?
Do you need "pink" or "white" noise ?
Greetings,
