Hi All,
how can i prevent aWeld() functioning from false triggering.
When
while (weldExitFlag ==false) is triggered, the aWeld() is also triggered at times. How can i prevent that ?
Code:
#include <Arduino.h>
#include <EEPROM.h>
#include <NTC_Thermistor.h>
#include <PinChangeInterrupt.h>
#include <Servo.h>
#include <Wire.h>
#include <hd44780.h>
#include <hd44780ioClass/hd44780_I2Cexp.h>
hd44780_I2Cexp lcd;
Servo myServo;
// Const Variables and pin assinged
const byte ENC_SW = 3; // Encoder Switch
const byte rdy = 4; // READY LED
const byte servoPin = 6; // Servo
const int ENC_PinA = 7; // PIN A of Encoder
const byte bzr = 5; // Buzzer
const int ENC_PinB = 8; // PIN B of Encoder
const int buttonPin = 9; // Weld button
const byte cs = 10; // Contact Sense
const int TRIAC = A1; // Load
const int shortPress = 1;
const int longPress = 2;
const int longerPress = 3;
const int tgr_dly = 5084; // delay after zero cross at peak sine - average of 50/60Hz
const int shortTime = 200; // if equal longTime there is no unrecorded press
const int longTime = 500;
const int longerTime = 2000;
const int pause = 450; // pause value between dual pulses
const int delayTime = 50; // bounce delay for Encoder Switch
// Variables
#define Temp A6 // NTC PIN
#define RR 10000 // Reference Resistance
#define NR 10000 // Nominal Resistance
#define NT 25 // Nominal Temperature
#define B_Val 3435
NTC_Thermistor *thermistor;
byte zCd = 2; // Zero Crossing Detect
//byte weldCont = false;
byte menuSelect = 0;
byte stayInMenu = false;
byte weldExitFlag = true;
byte previousButtonState = HIGH;
byte buttonState = HIGH;
byte prevENC_SWstate = HIGH;
byte ENC_SWstate = HIGH;
byte buttonFlag;
//byte resetFlag = false;
byte manualWeld = 0;
byte testLoop = 1;
byte cs_State = HIGH;
byte prevCS_State;
byte currCS_State;
byte confMenu;
byte rdyState;
byte noCtc;
byte ctc;
byte currCtc;
byte prevCtc;
byte prevWeldFlag;
int ENC_PinAState = LOW;
int ENC_PinALastState = LOW;
int WeldTime = 30; // read value from rotaryEncoder()
int prevRotaryVal;
int W2Addr = 110; // Address block to store W2 value
int PreWeldAddr = 120; // Address block to store PreWeld time
int startSrvAddr = 130; // Address block to store servo Start degree
int endSrvAddr = 140; // Address block to store servo end degree
int SrvPotMap1;
int SrvPotMap2;
int counter; // Auto weld counter
int WeldStepValue; // Value of POT in milliseconds
int OldWeldStepValue; // Old value of POT
int PotValue; // Actual POT value
int ConfigureVal;
int w1Value = 10;
int pValue = 50;
int select;
int Counter1;
int Counter;
unsigned long TimeStamp;
unsigned long ENC_SWpressDuration;
unsigned long buttonPressStartTimeStamp;
unsigned long buttonPressDuration;
unsigned long timeCheck = 1000; // time to check zero cross error
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long prevT;
unsigned long currT;
unsigned long delayT = 500;
boolean startTimeout = false; // zc sense error timeout
volatile boolean zeroCrossingFlag = false;
void setup()
lcd.clear();
lcd.begin(16, 2);
thermistor = new NTC_Thermistor(Temp, RR, NR, NT, B_Val);
ServoReturn();
//w1Value = EEPROM.read(PreWeldAddr);
SrvPotMap1 = EEPROM.read(endSrvAddr);
SrvPotMap2 = EEPROM.read(startSrvAddr);
//WeldTime = EEPROM.read(W2Addr);
pinMode(buttonPin, INPUT_PULLUP);
pinMode(ENC_PinA, INPUT_PULLUP);
pinMode(ENC_PinB, INPUT_PULLUP);
pinMode(zCd, INPUT_PULLUP);
pinMode(cs, INPUT_PULLUP);
pinMode(ENC_SW, INPUT_PULLUP);
pinMode(servoPin, OUTPUT);
pinMode(TRIAC, OUTPUT);
pinMode(rdy, OUTPUT);
pinMode(bzr, OUTPUT);
pinMode(A2, INPUT);
pinMode(A4, INPUT_PULLUP);
pinMode(A5, INPUT_PULLUP);
attachInterrupt(0, setFlag, FALLING); // zero cross
attachPCINT(digitalPinToPCINT(ENC_PinA), rotaryEncoder, CHANGE);
//attachPCINT(digitalPinToPCINT(ENC_SW), resetENC, RISING);
attachPCINT(digitalPinToPCINT(buttonPin), WeldExit, CHANGE);
delay(10);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Max Weld");
lcd.setCursor(12, 0);
lcd.print("v3.0");
lcd.setCursor(0, 1);
lcd.print("GT Designs");
delay(2000);
lcd.clear();
Display();
startupTone();
Serial.begin(115200);
// ------------------------------------------------ FUNCTIONS ---------------------------------
void startupTone()
tone(bzr, 2500);
delay(120);
noTone(bzr);
delay(240);
tone(bzr, 2500);
delay(120);
noTone(bzr);
void weldTone()
if (manualWeld == 0)
tone(bzr, 2322);
delay(70);
noTone(bzr);
tone(bzr, 2222);
delay(70);
noTone(bzr);
else
tone(bzr, 3153);
delay(50);
noTone(bzr);
void saveSuccess()
tone(bzr, 2025);
delay(300);
noTone(bzr);
/*void resetENC()
if (resetFlag == false)
Counter1 = 0;
void Display()
lcd.clear();
lcd.setCursor(1, 0);
lcd.print("W1:");
lcd.print(w1Value);
myServo.detach();
void rotaryEncoder()
ENC_PinAState = digitalRead(ENC_PinA);
if (digitalRead(ENC_PinB) != ENC_PinAState)
Counter1--;
else
Counter1++;
int readEncoder()
noInterrupts();
int copyCounter = Counter1;
interrupts();
return (copyCounter) >> 1;
void Weld() // Actual weld
delay(300);
myServo.attach(servoPin);
digitalWrite(rdy, LOW);
ServoStart();
//buttonState = digitalRead(buttonPin);
zeroCrossingFlag = false; // set flag false and wait for next zero crossing
while (!zeroCrossingFlag)
delayMicroseconds(tgr_dly);
digitalWrite(TRIAC, HIGH);
delay(w1Value); // preWeld time ms
digitalWrite(TRIAC, LOW);
delay(pause);
delay(WeldTime);
ServoReturn();
myServo.detach();
weldTone();
lcd.clear();
void aWeld() // Auto weld
if (currCtc == 0 && prevCtc == 1)
Serial.println(currCtc);
Serial.println(prevCtc);
Serial.println(" ");
prevCtc = currCtc;
ServoStart();
delay(pause);
delay(WeldTime);
ServoReturn();
myServo.detach();
weldTone();
void WeldExit() // Interrupt to exit Auto Weld
void setFlag()
zeroCrossingFlag = true; // interrupt sets flag true
void ServoStart() // Increments to start position from Finish
for (int i = SrvPotMap1; i <= SrvPotMap2; i += 1)
myServo.write(i);
delay(5);
void ServoReturn() // Increments to Finish position from Start
for (int i = SrvPotMap2; i >= SrvPotMap1; i -= 1)
myServo.write(i);
delay(5);
int clearSelectPointer(int checkPointer)
switch (checkPointer)
case 1: // for select 1
lcd.setCursor(0, 1); // 2
lcd.print(" ");
lcd.setCursor(8, 1); // 3
lcd.print(" ");
break;
case 2: // for select 2
lcd.setCursor(0, 0); // 1
lcd.print(" ");
lcd.print(" ");
break;
case 3: // for select 3
lcd.print(" ");
lcd.print(" ");
break;
case 4:
lcd.print(" ");
lcd.print(" ");
lcd.setCursor(8, 1); //3
lcd.print(" ");
break;
return (checkPointer);
// ------------------------------------------------ END OF FUNCTIONS --------------------------
void loop()
while (!zeroCrossingFlag) //&& (millis() - startTime < timeCheck))
/* hang inside while loop until either zeroCrossFlag or timeout occurs
both conditions need to be met to stay in while loop
lcd.print("W1:");
lcd.print(w1Value);
lcd.setCursor(1, 1);
lcd.print("W2:");
lcd.print(WeldTime);
lcd.setCursor(9, 0);
lcd.print("T:");
lcd.print(String(thermistor->readCelsius()));
lcd.setCursor(9, 1);
lcd.print("P:");
digitalWrite(rdy, HIGH);
ENC_SWstate = digitalRead(ENC_SW);
if (ENC_SWstate != prevENC_SWstate)
if (ENC_SWstate == LOW)
Counter1 = w1Value / 10 << 1;
Counter++;
confMenu = 1; /*
Serial.print("Pass:");
Serial.println(Counter);
Serial.print("Counter:");
Serial.println(Counter1);
Serial.print("W1:");
Serial.println(w1Value);
Serial.print("W2:");
Serial.println(WeldTime);
Serial.print("pValue:");
Serial.println(pValue);*/
prevENC_SWstate = ENC_SWstate;
while (confMenu == 1)
select += 1;
select = select % 4;
/*Serial.print("Select:");
Serial.println(select);
Serial.println(" ");*/
if (select == 0)
noInterrupts();
interrupts();
if (select == 1)
noInterrupts();
Counter1 = WeldTime / 10 << 1;
interrupts();
if (select == 2)
noInterrupts();
Counter1 = pValue / 10 << 1;
interrupts();
switch (select)
case 0: //W1
clearSelectPointer(1);
lcd.print(">");
w1Value = readEncoder() % 6 * 10;
if (w1Value <= 0)
w1Value = 0;
lcd.print("W1:");
lcd.print(w1Value);
lcd.print(" ");
break;
case 1: //W2
clearSelectPointer(2);
lcd.print(">");
WeldTime = readEncoder() % 51 * 10;
if (WeldTime <= 0)
WeldTime = 0;
lcd.print("W2:");
lcd.print(WeldTime); //lcd.setCursor(5, 1);
lcd.print(" ");
break;
case 2: //P
clearSelectPointer(3);
lcd.print(">");
pValue = readEncoder() % 11 * 10;
if (pValue <= 0)
pValue = 0;
lcd.print("P:");
lcd.print(pValue);
lcd.print("%");
lcd.print(" ");
break;
default:
clearSelectPointer(4);
confMenu = 0;
select = 0;
break;
while (weldExitFlag == false) // begin Auto Weld
delayMicroseconds(8600); // Sense voltage (after zero cross). higher number, lower voltage.
delayMicroseconds(200);
cs_State = digitalRead(cs);
currCS_State = cs_State;
if (currCS_State == prevCS_State)
ctc = 0;
else
ctc = 1;
prevCS_State = currCS_State;
currCtc = ctc;
Serial.println(ctc);
if (currCtc != prevCtc)
if (currCtc == LOW && prevCtc == HIGH)
delay(300);
aWeld();
prevCtc = currCtc;
buttonState = digitalRead(buttonState);
previousButtonState = buttonState;
currCtc = prevCtc;
} // End Auto weld
if (zeroCrossingFlag)
// exit while loop due to flag set
switch (checkButton())
case shortPress:
lcd.clear();
lcd.print("Welding....");
Weld();
break;
case longPress:
lcd.clear();
lcd.print("Auto Weld");
delay(800);
lcd.clear();
weldExitFlag = false;
break;
case longerPress:
break;
// end of Loop
byte checkButton()
byte event = 0;
// button pressed
if (buttonState == LOW && previousButtonState == HIGH)
delay(20); // blocking debounce routine
buttonState = digitalRead(buttonPin); // read button again
buttonPressStartTimeStamp = millis();
startTimeout = true;
// button released
if (buttonState == HIGH && previousButtonState == LOW)
buttonPressDuration = (millis() - buttonPressStartTimeStamp);
startTimeout = false; // duration determined no timeout required
if (buttonPressDuration > 0 && buttonPressDuration <= shortTime)
event = shortPress;
buttonPressDuration = 0;
if (buttonPressDuration > longTime && buttonPressDuration <= longerTime)
event = longPress;
// button not released and still timing
if (buttonState == LOW && startTimeout == true && (millis() - buttonPressStartTimeStamp) > longerTime)
event = longerPress;
return event;
When
