Pressure signal
Doppler2902
Joined Sep 15, 2020
37
Hi, I'm trying to get this pressure signal with operational amplifiers for a school lab but I don't know how I could get the sine waveshape of the signal which is a noise signal, I know that I obtain the square wave shape through a comparator configuration, any advice is helpful!
38,683
You can run the signal through an RC high-pass filter to reduce the sinewave noise.
Pick a filter corner frequency somewhere between the sinewave frequency and the pulse rep frequency.
A lower frequency will suppress more of the sinewave, but also distort the pulse more, so you look for the happy medium.
Irving
Joined Jan 30, 2016
5,195
I'm guessing this is an experiment for the students to find ways to recover the wanted signal in the prescence of noise (hum, etc)?
What signals are you applying at S1 and S2? That's a complicated way to get a simple fixed pulse train...
Is the sine wave 'noise' related in frequency/phase to the pulses or should it be different (ie non-coherent noise)?
ericgibbs
Joined Jan 29, 2010
21,532
hi Doppler,
I would add another 741 to the output of the comparator circuit, sum/mix the Sine wave and the Square wave signals that way.
Do you follow, OK.?
E
ericgibbs
Joined Jan 29, 2010
21,532
hi Doppler,
This will give the basic idea, as this is homework you can finalize the circuitry.
E
Post your circuit when ready...
ericgibbs
Joined Jan 29, 2010
21,532
hi D,
I would suggest you do not use the term 'noise' if the modulating signal is a sine wave form factor.
What is the source of the Sine wave which you are using to drive the comparator input.?
E
Doppler2902
Joined Sep 15, 2020
37
hi D,
E
Oh, I was saying noise because I have to filter that signal for obtain the blue signal
ericgibbs
Joined Jan 29, 2010
21,532
hi D,
Do you know the frequency 'range' of the sine wave input and is the amplitude fixed.?
The filter you have will affect the 'square' wave shape.
E
