Presetting two 7 segments with a value using 4510 and 4511 drivers
ericgibbs
Joined Jan 29, 2010
21,470
hi,
No that will not work.
Use the Resistor and Capacitor as I have drawn it in post #20
Just connect the two LD pins together to the C4 cap.
The 4069 is not required between the Carry and Clock pins, just a direct connection as i the original circuit.
E
olivia_26_
Joined Sep 8, 2020
21
I have removed the invertor and have connected the LD pins together.
I was given a sheet on loading a number on 1 seven segment but there is no information on how to load onto 2. This is where I got the idea for the not gate.
djsfantasi
Joined Apr 11, 2010
9,237
I want to count down from 13 so the values would be 0001 and 0011
So? What do you need to do with those two values?
I realize you didn’t know how to load a value from which you can count down. But you have and understand all the information that you need. Forget what you don’t know. Think about what you do know and how to use that knowledge to solve your problem.
It’s right there. I’ve given you several direct hints. But you’ll learn a lot more if you figure it out for yourself. Give it one more college try!
olivia_26_
Joined Sep 8, 2020
21
Ok I have done what I think would pre-set the value and when I tested it, it froze in this position. I'm not sure if that's to do with the pulse settings or whether I have just connected it incorrectly. I have attached my tester flowchart with the pulse properties.
ericgibbs
Joined Jan 29, 2010
21,470
hi,
Why have you removed the Res/Cap circuit I posted in post #20.?
In your latest diagram the two LD's are not connected, so the circuit will 'freeze'
The LD1,2,4,8 connections look OK
E
olivia_26_
Joined Sep 8, 2020
21
Sorry, I completely missed that post!
I swapped them around and when I started the circuit it started to countdown from 10 but then got stuck at 9 so I''m thinking its something to do with how I have programmed the pulses.
ericgibbs
Joined Jan 29, 2010
21,470
hi,
OK,
So check your Pulse program and post back your result, we can go from there.
E
Updated:
For information only this image is a the simplest LTSpice sim of 4510's with a LD pulse, loading the number '13' into the 4510's
You can see that the Loading of the number '13' is correct.
olivia_26_
Joined Sep 8, 2020
21
It will still only pulse for 1 digit no matter what pulse setting I use. I looked at the diagram you sent and noticed that both reset pins went to ground so I changed the one at the top and it now says 13!!
ericgibbs
Joined Jan 29, 2010
21,470
hi,
That's good to hear, so now check the down counting action.
Why have you removed the Reset switch.
Post what you see.
E
olivia_26_
Joined Sep 8, 2020
21
I changed the flowchart by taking out the other components and just used single pulses and waits and I managed to get it to count down to 8 from 13!!
olivia_26_
Joined Sep 8, 2020
21
Hi, Thanks so much for your help.
We just had to design the final circuit for tomorrow and make a test flowchart to make sure everything was working. I think we were going to start drawing up pcbs today in class but my school is now closed. For now, I'm just going to leave it there as I have been working on it for ages and I have some other work to get caught up on!
Thanks again for your help as I would not have been able to do this without you.
