Precise voltage reference VLSI
mos_6502
Joined Dec 11, 2017
48
Hi to all,
Is there a way to generate a precise reference voltage starting from a stable external power supply (eg +3 / -3V from +2.5 / -2.5v)?
I should do this in an IC (I'm simulating with Tanner EDA and a 0.25um layout).
I heard about the "charge pumps", could I use one?But I do not know how they work and even what are the design criteria.
Can you help me?
danadak
Joined Mar 10, 2018
4,057
The most stable internal commercial Vref I am aware of on FPGA,
VLSI, is a just borderline reference on PSOC 5LP family of ARM
micros. Its +/- .1 %. I do not know if that is laser trimmed at production
or its intrinsic properties. Note thats a 25 C spec.
Regards, Dana.
dendad
Joined Feb 20, 2016
4,251
In a couple of our products, we used pretty good voltage reference ICs.
The first is one with a temperature controlled heater built in.
It is an LM3999H.
The lower spec version uses a MAX6341.
Both circuits have precision resistors, 15PPM, 0.1%.
Better Vrefs and resisters can be used but these are quite adequate. Probably better Vrefs are available now too.
The ADC has a MUX on the inputs so the processor can read a terminated input for a zero reading, then a measured test voltage that is formed from the Vref and the precision resistor in a voltage divider, and then the unknown input signal voltage.
The test voltage is measured on setup with a lab quality meter and the value stored in EEPROM.
This way, the system can self calibrate for more accurate readings.
This setup has been in use now for quite a few years in precision water MagFlow meters.
