a way to make 4channel 0.01V precise voltage
Eneloop
Joined Jan 4, 2019
hi, Im making a over network-contorled drone,
and I hacked a drone controller, made other things but
my system is making voltage different value when i use other power supply (or even when I use same battery but less charged), with same pwm.
so, i'm trying to use DAC.
need to make 1.400~1.900V +-0.01V precission of 4 output channel
can this be the sollution?
DAC : https://www.analog.com/media/en/technical-documentation/data-sheets/DAC8420.pdf
with 2.5 voltage reffernce chip, single 5V supply system, MCU: arduino micro.
danadak
Joined Mar 10, 2018
4,057
Use a 2.048 reference will give you a convenient lsb step of .5 mV / lsb.
Of course you have to do a complete error budget to see if it meets your goals
over T and V.
Regards, Dana.
Eneloop
Joined Jan 4, 2019
Welcome to AAC!
Why do you think you need the tolerance to be so tight?
cuz when i tested my controller and drone simullator, from 0.03V the drone started to move.
(you defenetly would not want your drone to move on steady mode)
so, +-0.02V is seems little dangerous, i want to be +-0.01V
Eneloop
Joined Jan 4, 2019
Is it really offset that you need to adjust? That should be easier than going for precision of the voltage.
im not sure what you meant but,
the controller have 1.635V at natural(analog stick), and its very sensitive.
so.. the exact voltage is needed rather than offset.
(and i wrote 0.01 but actualy it was 0.001)
DickCappels
Joined Aug 21, 2008
10,662
If you only need the voltage to be exactly 1.635V with and the other voltages can be a little off, then you can solve the problem pretty easily with an offset adjustment. As danadak pointed out you will have to be careful to choose a voltage reference that will be stable enough over temperature.
Eneloop
Joined Jan 4, 2019
ok, ill try with good voltage references.
thanks lot for the comments
