Power vs Current/Voltage in Speakers! (2)
johnyradio
Joined Oct 26, 2012
615
Can we assume that the voltage sent to the speakers is the same voltage as the power supply?
Eg, if my amplifier is powered y 25 volts DC, can we assume the speakers see 25 volts? So if we have a "100 Watt" amplifier, then the speakers will see 25V @ 4A? Wondering about class D amps in particular.
38,943
No.
It can be 25Vpp from a D amp, but the average voltage is determined by the audio signal in which determines the duty-cycle of the output to the speaker.
johnyradio
Joined Oct 26, 2012
615
A bridged amp can deliver nearly twice the supply voltage p-p. And one with a transformer output can deliver any voltage you want.
Perfect answer. So, is this correct?
  • a non-bridged amp without a trafo can't exceed Vsupply
  • a bridged amp without a trafo can nearly double Vsupply
  • a step-up trafo will multiply whatever Vmax is coming from the amp
BobTPH
Joined Jun 5, 2013
11,678
Actually, as an RMS voltage, a bridged amp can reach 0.707 X Vs, and a non-bridged, non transformer one can reach only 1/2 that. Class D amps are typically bridged.
I actually misspoke in my previous post, though I did say p-p.
