Power transformers - AC to DC or DC to DC
RogueRose
Joined Oct 10, 2014
375
I am wondering if a transformer like those used in microwaves can be used from a DC source instead of an AC source. Also if DC is desired, is there any reason that the bridge rectifier can't be in front of the transformer? Is there any benefit of rectifying before or after the transformer?
bertus
Joined Apr 5, 2008
22,956
Transformers do not work with DC, thats why the rectifier is used after the transfromer.
In SMPS powersupplies there is a rectifier at the entrance of the powersupply, but the DC that is created is switched very fast so a high frequency transformer can be used, wich is much smaller as a conventional transformer.
Have a look at the attached PDF on how a powersupply is designed.
30,717
No you cannot use DC on a normal AC designed transformer.
The only one that comes close is a synchronous transformer that was often used on car radio supplies, where the 12vdc primary was alternated in synchronous with the secondary windings producing a square wave supply that was then rectified. Achieved with a synchronous vibrator.
But still AC.
Yes...transformer can be used on DC if it is switched very fast as it is used in smps power supply. Power supply is first rectified and then switched very fast..also there is a need of high frequency transformer having small size and thus saving space..
recklessrog
Joined May 23, 2013
985
Methinks the OP won't live very long if he starts playing around with microwave oven transformers with no knowledge of what he is doing.
Desist before you die!
DickCappels
Joined Aug 21, 2008
10,661
Voltage is developed on a transformer's secondary by changing current in the primary. If the current in the primary is constant, as it would be if soon after DC were applied to the primary, there would be no voltage on the secondary except for a brief pulse when the DC source is attached. Post #4 expands on that concept.
