Power through parallel resistors.
Pulsed
Joined Sep 10, 2012
41
This one confuses me. You have three resistors, 2 4r and one 6r, each with a power limit of 1 Watt. If they are all put in parallel so that they form a composite resistor, what is the max wattage that the composite resistor can handle before it burns up?
I thought 3W but am clearly wrong. I also got this explanation, which did not help me.
"Because 3W on the three resistors in // means 2.12V across each resistor (U=PR−−−−√) and then U^2/R=(2.12V)^2/4ohm=1.124W for the 4ohm resistors. It is higher than 1W and can not be correct. Don't forget than we do not have three equals resistors."
Many thanks for your kind responses!
#12
With all resistors in parallel, they must all have the same voltage. The lowest resistance will have the highest current, and so, the highest wattage for any voltage applied to all three. That will find the highest voltage allowed. Then you can calculate the power disipated in each resistor.
Pulsed
Joined Sep 10, 2012
41
Thanks 12, but I would appreciate if someone could show me how you would approach this practically?
justtrying
Joined Mar 9, 2011
439
can I ask how you came up with 3W? And does the question ask for max wattage, because you cannot exceed the rating and they are already rated for 1W.
Pulsed
Joined Sep 10, 2012
41
Certainly, the original question was: Given that each individual resistor can dissipate up to 1 watt of power before burning up, how much total power in watts ( W ) can the smallest-valued composite resistor dissipate before burning up? Answer: 3
incorrect
I thought 3 because, given that each resistor was rated at one watt, three in parallel would handle 3 watts. I see now that logic is flawed because the resistances are different.
How would you go about putting this into an algebraic equation? That is where I am really stuck. Upon searching Google I have not come up with this seemingly simple answer.
justtrying
Joined Mar 9, 2011
439
To be honest this question is throwing me off:
you know that the rating is 1W and the resistors are in parallel, so you can calculate maximum voltage that the resistors can handle before the rating is exceeded. To do that, as #12 said already, lowest resistance = highest current, therefore that will give you the highest voltage allowed.
the problem I have with the question, is that all values are based on finding the maximum allowable voltage (from using 1W value) so the answers end up being 1W or less, i.e. just the rating. I am either missing something or this is a very poor question.
JoeJester
Joined Apr 26, 2005
4,390
The lowest valued resistor "sets" the maximum voltage you can have on the parallel circuit.
Find the voltage for 1W on the lowest resistance.
The question asked for the total power .... so now that you computed the maximum voltage on the circuit, just compute the power for the remaining resistors. The correct answer will be 1W + next resistors power + next resistors power.
Use Bertus' diagram.
JoeJester
Joined Apr 26, 2005
4,390
justtrying ...
One must be careful in the homework section when posting. We prefer not to give the answer, but to make the OP understand where they went astray so they can have the same "ah ha" moment you did.
justtrying
Joined Mar 9, 2011
439
Yes, my apologies to Pulsed. I've never done this before. I am sure the OP will post his work. I've fixed my reply. I don't know why I slipped.
Pulsed
Joined Sep 10, 2012
41
Here you have a visualisation of the circuit:
You can calculate the voltage using P = U*U/R.
More info can be found here:
http://www.allaboutcircuits.com/vol_1/chpt_2/4.html
I am not given a voltage, or a current with which I can calculate the power, which is the part I do not understand. With just the 1w rating and the fact there are three resistors, one of which is a different value.
bertus
Joined Apr 5, 2008
23,005
I have given you an hint how to calculate the voltage:
You will need to convert the formula to get the voltage.
JoeJester
Joined Apr 26, 2005
4,390
If you are given a 1 W resistor of 4 ohms ... what is the maximum voltage you can apply to it without blowing it up?
a. Do you know how to find the voltage when given the power and the resistance?
b. Can you convert the formula that Bertus has given you?
Pulsed
Joined Sep 10, 2012
41
So...
The composite resistance of 4 ohm, 4 ohm and 6 ohm values in parallel is equal to 1.5 ohms. Now you just convert the subject of the formula for power to V.
P=(V^2)/R, P*R=V^2, SQRT(P*R)=SQRT(V^2), V=SQRT(P*R)
Substituting values: V=SQRT(P?*1.5), V=?.
I'm just coming stuck.
bertus
Joined Apr 5, 2008
23,005
What would happen if you calculate the voltage using ONE 4 Ohms resistor?
There is given that the resistors may dissipate 1 Watt.
Pulsed
Joined Sep 10, 2012
41
It would equal SQRT(1*4). You would have a maximum of 2 volts before the resistor burned up.
