I have a cheap bench power supply model 303D Arksen, 30V, 5A which hasn't been used much. It was fine until today I noticed I have no current when I select high current mode. In low current mode the current is restricted to 50mA, and that works like new. I suspected a blown fuse but it doesn't have fuses. The built-in voltmeter and ammeter work without issue. It will supply the voltage I set it to, but under any load there is no current unless I select the low current output mode. The voltage display does not go to zero under load, it stays the same. I verified it holding voltage with a multimeter and a scope. Seems like an open circuit. I wasn't able to find a schematic.
I have verified 25VDC on +V pin 4 of the LM324N quad op-amp IC. I've verified both TO3 power transistors are good and working. I have verified both current pots work with power off, and by checking for varying voltage drops with power on while adjusting them. I have yet to find a bad component or connection. Any help is appreciated.
