Power Supply - Solid State Guitar Amp Board
LowQCab
Joined Nov 6, 2012
5,102
Keep in mind that the LM1875, while an excellent and simple choice,
requires a minimum Power-supply of ~16-Volts for stable-operation,
which will then produce around ~7 to ~8-Watts of Output-Power,
and only costs around ~5-Bucks from DigiKey-Electronics.
Up to ~30-Watts of Power is feasible with a much-higher Supply-Voltage.
An SMPS from a LapTop-Computer would be a great choice for a Power-Supply for this application,
and may be able to generate about ~10=Clean-Watts of Power with this Chip.
With a carefully selected Speaker, and a properly designed Cabinet,
this setup could be a very respectable Guitar-Amp,
which is also capable of handling small Gigs.
If You think your Wood-working chops might be better than your Electronics expertise,
You could build a serious, real, premium-quality, ~25-Watt-Guitar-Amp for just over ~$150.oo,
by ordering Cabinet-Plans from Bill Fitzmaurice,
and 2-Speakers, and a Digital-Amp, from Parts-Express.
Note ........
The Amp uses the "Chinese-Power-Rating-System", don't believe it,
in "Real-RMS-American-Watts" the Output is maybe around ~25-Watts or so.
This setup can easily generate over ~100db of "clean" Audio-Output,
and substantially more when over-driven into Distortion.
The Speakers can handle ~10X as much Power if You want to up-grade the Amp.
35,177
I am giving you relatively simple options, single channel, 20W min, 12VDC supply.
Use a chassis mount 1/4" jack. Use shielded audio cable to connect from the 1/4" jack to the amplifier module.
LowQCab
Joined Nov 6, 2012
5,102
For best results, You may need to add a Pre-Amp Op-Amp, before the Main-Amplifier.
I'm not exactly sure what the ideal-gain should be,
but a generic Guitar-Amplifier normally has to be capable of directly Amplifying a Guitar-Pick-Up.
This is probably in the range of ~80X to ~150X-Total-Amplifier-Gain for full Amplifier-Output.
This Gain figure is highly dependent on the maximum Output-Voltage that the Amplifier is capable of.
