And the component is?Well, if you are expecting DC at the output, you are missing a component.
Bob
A capacitor, to convert the rectified AC into DC with some ripple.And the component is?
I put a 470uF electrolytic across the output. Still 0V dc.The size of the capacitor is determined by the load current and how much ripple voltage you can tolerate.
I just used 1N4148 because it was handy.Hi:
I am attempting to simulate a simple power supply circuit but it isn't working correctly. Can someone
please advise where I have gone wrong. Thanks.
Thanks. I have no idea about the models. It is hard to find models, let alone ones that actually work.I just used 1N4148 because it was handy.
Also- make sure your diode models are correct.
I am surprised at the dc waveform, not what I was expecting.Thanks. I have no idea about the models. It is hard to find models, let alone ones that actually work.
Mods Note :That's called ripple.
Are you running a transient analysis, over a period which covers several cycles?why are the dc measurements all zero?
PS4 pro power supply coil whine | Power Electronics | 0 | ||
Taser (High voltage) generator circuit messing with power supply | Power Electronics | 3 | ||
R | Basic DIY Linear Power Supply Question | Power Electronics | 8 | |
1 | Power supply simulation issue | Power Electronics | 2 | |
E | LM317 power supply simulation problems | Power Electronics | 16 |
