Power supply schematic help
Mathews M John
Joined Jul 14, 2015
8
I am pretty new here but have used many of the resources from the website for a couple of my past projects. I am working on a handheld device and want to use +/-3.3V to power some opamps. I have been searching quite a lot to learn how to make a dual power supply. During my search, I came across this schematic. However, I don't understand how the inductors L1 and L2 helps in stepping down the voltage. Can someone help explain this circuit ?
MikeML
5,444
U4 is a 12V input, +/-5V output DC to Dc converter smps, which will have high frequency noise on its outputs. L2 and L3 acting with C17 and C18 form a low-pass filter to get rid of the noise.
Mathews M John
Joined Jul 14, 2015
8
As can be seen here , U4 is a 5 to +/-12 V DC/DC converter. What I don't understand is how the inductors and resistors are used to get the voltage down from 12V to 5V
MikeML
5,444
No, the input to the brick is 12Vdc. The output from the brick is +/-5Vdc, but noisy. The inductors are there to help filter the noisy 5V.
MikeML
5,444
Ok, I see Scott found the data sheet. The schematic is mislabeled. The output terminals should say +12V and -12V. The inductors are still part of the final filtering to get the smps switching noise off the outputs.
12,132
They don't. The outputs on your schematic are labeled incorrectly, but the title is correct. The outputs are +/-12 V, and that's that. Each inductors is part of an output L-C filter to remove switching noise. The converter, not the filters, is doing the converting.
38,511
Thank you guys. I was trying to understand this circuit for ever. Are R15 and R16 also a part of the filter?
The spec sheet says the output ripple of that supply is 75mVpp with a fundamental switching frequency of 80kHz.
The output filter will reduce that noise (likely needed if you are powering sensitive analog circuits).
I think R15 and R16 are to add damping to the filter to minimize ringing at the LC resonant frequency.
ian field
Joined Oct 27, 2012
6,536
The picture posted (link) elsewhere doesn't look like a heatsink job, so unlikely a linear - my guess is those inductors are external buck inductors. It may require further filtering.
Technically; the buck coil and output capacitor are a LPF in their own right - the question is; which are those shown in the application example?
