Power supply LM317
SpNw
Joined May 27, 2020
13
The circuit in post #18 looks reasonable, but how does the simulator get two different vol6tages on the output line? 20.4035 at the regulator, and 23.7434 at the output. I find that a bit confusing.
Also confusing is the use of a six digit voltmeter.
The output number that you see is not the voltage, but yes the current, so I devide the current by 3 darlington transistores to cause less power dessipation in LM317, at 1.5A max of output, I got only +/-200mA passing throw the LM317.
Audioguru again
Joined Oct 21, 2019
6,826
The unnumbered transistor below Q5 seems to have its Emitter and Collector interchanged OR it os a NPN transistor.
Yes, it has its collector and emitter connected backwards. It is supposed to begin turning on when the LM317 current in R2 reaches about 0.7V/22 ohms= 32mA.
I notice that the old 741 opamp is not powered.
SpNw
Joined May 27, 2020
13
Sorry for bothering you, but do you think that is a good way to power LM741, (And sorry for the amateur questions, but I'm a "freshman" in this field :p)
dl324
Joined Mar 30, 2015
18,521
Looks okay. Could say better if you showed enough circuitry to be more certain.
dl324
Joined Mar 30, 2015
18,521
Here, ty!
The relevant part:
Not sure what kind of games you're trying to play by posting different schematics. The other one used a different zener.
It'll work, but the power dissipation in the zener could be reduced significantly.
Not sure why an LM741 is being used when only half of the LM358 is being used.
Deleted member 115935
Joined Dec 31, 1969
An op amp is always better if it has a decoupler on its power input pin,
