Power supply for a Microcontroller/microprocessor in a boat
vegovs
Joined Jun 13, 2018
I am making a project which includes a Raspberry Pi or an Arduino that needs power from the existing circuitry on different boats. The voltage may differ from 10-30V and i need to make a Power Supply that lowers it and keeps it regulated to 5V. I do not remember anything from my electronics class and need help!
The question is, how can i get 5V DC from circuitry that may have 10 to 30 V?
dl324
Joined Mar 30, 2015
18,457
Welcome to AAC!
Use a voltage regulator. Plain old 7805 linear regulator, LDO, buck; your pick. Just make sure you consider maximum input voltage and power dissipation.
vegovs
Joined Jun 13, 2018
Welcome to AAC!
Thank you Dennis, could you give me an example when i should consider max-voltage and power dissipation?
dl324
Joined Mar 30, 2015
18,457
With a linear regulator, power dissipation can be an issue.
If you have 30V in, 5V out and a current of 1A, the regulator would dissipate
\( \small P = I*V = 1A * (30-5V) = 25W \)
Without a good heat sink, a 7805 would go into thermal protection and not be very useful.
