Hi all. Taken apart a carlsbro portable mixer amp T150 pa
The power supply has gone down.
tested a few parts & replaced faulty ones. 2x fqp13n50's 1k resistor & 4007 diode
but it still won't power up ? all i get is the red led. not sure if its worth trying..
So going to replace. But the input to the amp says
32v+ grd 32v- the power supply i think is a switch mode ac to dc then through a
few fpq13n50 & isolator...
But can i put a 32v dc transformer onto the amp & is the ground in the middle of the 3 pins
32v+ gnd 32v- is this earth/case sorry but i can get a transformer but it's just + & -
pressume is 32v+ 32v- ...This will let me know if the amp is OK
If not then thinking of changing the amp & power supply
But will need to find out what voltage the mixer section runs on.
it is connected with a ribbon type cable. thin it's 5v as there is a 7805 reg & 7915 reg
there is no schematics for this unit so its a bit of a pain for me.
I'm not the best at working things like this out. any help would be great..
please view pictures if it helps.
chears jimbo
chears jimbo
