This circuit won't work without a path for transistor base current, and also some bias current for the zener. A resistor to GND is the simplest solution.Yes I was getting around to something similar to Ken's. His has the advantage of a modicum of adjustment.
Points to remember.
When not immersed may transistor will drop the full battery voltage so must be rated accordingly.
For this reason do not try the FET circuit referred to in post #2.
The polarity may be reversed by using an NPN transistor and reversing the LM385.
Either way the pass transistor needs to be about 500 mWatts or greater rating.
OK, I'll let it slip this time. Just see that it doesn't happen again.Hi Ron,
I'm sorry for creating another thread... I just think that I was confusing everyone as well as myself. So, I created this one and tried to provide more information for everyone to go on.
Thank You
StephenMG
