Power Supply Calculation
krishnan_hari83
Joined Feb 11, 2012
21
Guys,
Please clarify my doubt.
I am having 3 LEDs each of 4 V and 120mA.
What is the power supply I must give under the following conditions.
1. 3 LEDs connected in series
2. 3 LEDs connected in parallel.
Kindly advice me of the power supply calculation.
Krishnan.H
R!f@@
Joined Apr 2, 2009
10,014
In series u will need more than 12V @ 120mA max & one resistor.
In parallel u will need 4V @ 120 X 3mA
But I doubt this way would be advisable.
wmodavis
Joined Oct 23, 2010
739
For series - 12 V @ 120mA
For parallel - 4 V @ 360mA
But as R! suggests best to have resistors which will limit current.
mcgyvr
Joined Oct 15, 2009
5,394
I always wonder how many millions of LED's have been destroyed in the past 10 years because people think you can just hook them up like a light bulb and off you go..
Your power supply could be rated for 100V @ 50 Amps and still work just fine provided you include some sort of current limiting into your schematic (like a resistor in series with the LED to limit the current or other constant current supply)
studiot
Joined Nov 9, 2007
4,998
You might like to consider a series connection of two parallel pairs.
That way you can run from a 9V battery and a 4R7 half watt resistor.
