Power supply AC input Cut off voltage?
#12
I don't know. I never tried to run a 90 volt switching supply at 80 volts.
Do you mean all designs of all switching regulators, or one you can name?
#12
Correct, the formula needs to be changed to be able to calculate for Improper operating conditions like if the AC line voltage goes under to 80VAC , what is the ripple and how do I calculate it?
1) No, it doesn't.
2) First, you specify all conditions of voltage and current for input and output, then you post the schematic of the power supply. Then you might be able to create one formula for one power supply, but you will not get the Universal Truth for All Circuits.
SamEricson
Joined Apr 25, 2015
196
All kinds , every power supply will react differently when you supply it at 80VAC , the output DC voltage will either be stable or the power supply will turn off from the cut off and threshold point.
What is determining the power supply threshold point and cut off point
You adjust the AC variac until the linear or switching power supply turns off. What is determining this cut off point and threshold point? it might be 80vac or it might be lower depends on the power supply
#12
The answer to both of your questions is: "The way it's designed."
If you can't name the power supply, nobody can name how it works when you abuse it.
SamEricson
Joined Apr 25, 2015
196
adding more capacitors in parallel will maintain a constant % ripple value not to drift or change with the AC input voltage goes down to 80vac?
#12
Absolutely nothing.
There is no way to force the percentage of ripple on a power supply capacitor to remain the same for all operating conditions of load and line, including an input voltage below the design limits.
SamEricson
Joined Apr 25, 2015
196
I have seen very large capacitors 10,000 uf cap in power supplies that is before the filter caps for input line sag to keep the percentage of ripple on the output of a power supply in case the ac line drops down
SamEricson
Joined Apr 25, 2015
196
To answer your question
actually UPS power supplies can have the AC voltage very low without any change to the DC output and ripple
#12
That's because they get their output power from a battery which still has the same voltage when the power line voltage gets too low.
SamEricson
Joined Apr 25, 2015
196
Yes it switches over,
you take the battery out of the circuit and and use an AC variac to lower the AC input and measure the cut off or threshold of the UPS switch over point which is about 90VAC
#12
90 volts? Not 80 volts? Why is that?
So that means I can expect every UPS everywhere to work without a battery until the power line gets to 90 volts?
12,145
so it's just magic?
it happens for a reason with a formula
It is clear from your questions and responses to our answers that you do not understand how power supplies work. Without some basic understanding, none of the answers to your questions are going to make sense. If a device - ANY device - is operated outside of its design parameters, there are consequences. What those consequences are depends on what the device was designed to do. Without a schematic of a particular power supply design, general explanations will not satisfy your questions.
#12
Because the UPS wants to switch over as close to 115vac , that is what UPS designers set the threshold point of switching over
If the switching point is designed to be close to 115 volts, why do the UPS devices keep working with no battery as low as 90 volts?
