If you are reasonably convinced that the answer is wrong then you are missing nothing. If for some reason you think the answer is correct, but the diagram is wrong, then you might be overthinking things.I have come across this question and answer (500 Watts) in a set of training notes and it seems fundamentally flawed to me. Am I missing something here??View attachment 161628
Thank you,If you are reasonably convinced that the answer is wrong then you are missing nothing. If for some reason you think the answer is correct, but the diagram is wrong, then you might be overthinking things.
Trust me the remaining questions are not relevant. This is stand alone!!I think your question is taken out of context. You need to post the preceding 39 questions.
Seriously? I can't imagine why this would be necessary.I think your question is taken out of context. You need to post the preceding 39 questions.
There is no connection. That is why the TS and I think there is a mistake. Either the answer is wrong, or the diagram is wrong.In that case, I don't get it.
How does 1mW and 50mW relate to 500W?
This is a boss trap. If you say the answer is wrong, the teacher will say the diagram is wrong, if you say the diagram is wrong, the teacher will say the answer is wrong, in any case after the test its already too late to dispute the results....There is no connection. That is why the TS and I think there is a mistake. Either the answer is wrong, or the diagram is wrong.
This was not represented to be a test. It was one of a number of questions in a set of training notes. I understand your fascination with conspiracy theories, but they don't seem relevant here. In any case it is a poor example, with misleading information.This is a boss trap. If you say the answer is wrong, the teacher will say the diagram is wrong, if you say the diagram is wrong, the teacher will say the answer is wrong, in any case after the test its already too late to dispute the results....
I have no fascination about conspiracy theories, but I do not deny the truth either. Stop thinking that you are right, because you have only what someone tells you to base it on. After someone prooves that the Earth goes aroung the Sun, it will be too late to say I am sorry for all the witches I burned!This was not represented to be a test. It was one of a number of questions in a set of training notes. I understand your fascination with conspiracy theories, but they don't seem relevant here.
Thank you all for your input. Papabravo actually hit the nail on the head in his very first answer. The actual question appeared "as is" in the student questionaire but without the "answer" and all students have been responding correctly with 50mW as the answer.This was not represented to be a test. It was one of a number of questions in a set of training notes. I understand your fascination with conspiracy theories, but they don't seem relevant here. In any case it is a poor example, with misleading information.
by Aaron Carman
by Don Wilcher
by Jake Hertz
