I just burned up four STMicro L165 power op amps driving with a 0.5V amplitude square wave at ~1380 Hz using the Unity Gain circuit suggested in their datasheet. I was powering with +/- 15VDC and it seemed to work initiially, but saw a current draw of about 800 mA (versus a spec of 40 mA), increasing to 1.6 A after it was toast. As far as I can tell I have set up their unity gain configuration correctly, but the 1k across the inputs seems kinda odd and the 0.22 uF cap seems kinda big to be swinging around. Anyone have any insight on what I've done wrong? I generate the input square wave with a couple of TL082's set up as a relaxation oscillator passed through a variable gain attenuator then summed with a DC offset. I've been starting out with a low amplitude square wave with no DC shift while breadboarding the circuit, though. The square wave generation works fine. Ultimately I'm trying to drive a couple of Peltier modules in series, hence the need for a power op amp.
