power line of different phase anglle short circuit
falade47
Joined Jan 24, 2017
178
Please what happens when you create a contact relationship between voltage of different phase angle..like a short circuit
BR-549
Joined Sep 22, 2013
4,931
A short circuit doesn't have a phase angle. If one voltage meets another voltage with a different phase angle......the result can be much worse than a short circuit. It can be double worse.
It all depends on the angles.
You can see this in an intense manner when putting a generator on line.
The phase difference will be equal to the number of degrees the generator rotor shaft will try to rotate....instantly....when you flip the switch....so be careful.
This can turn a generator into a spherical ball of high velocity shrapnel.
falade47
Joined Jan 24, 2017
178
Y
Yeah..woudnt even try that..
RichardO
Joined May 4, 2013
2,270
The old method of getting the generators in phase was quite simple. (I remember seeing it done in an old black and white movie).
The were light bulbs connected between matching phases of two generators -- before connecting the generators together. The 3 bulbs were arranged as a triangle. When the off-line generator was running at nearly the same frequency as the power grid generators the bulbs would display a rotating pattern. When the bulbs rotated very slowly and then all of them were dark the generators were in phase. It was then safe to throw the switches that tied the generators together.
