Hi there,
This is my first post, so I hope that it is O.K.
I've been following along with a tutorial to build a bluetooth portable speaker.
Everything works as expected, until I introduce a 5v dc to 5v dc isolator between the regulated 5v and the bluetooth module.
The isolator is required in the circuit to eliminate a noisy ground-loop signal, which is audible.
With the bluetooth powered straight off the regulator, the audio signal comes through strong and clear, but so does ground loop interference noise.
with the isolator between the two, the ground loop noise is eliminated... but so is the audio! With a multi-meter, the isolator is receiving 5v and also supplying 5v, so it isn't faulty as far as I can tell. Even so, it reduces the audio output to the faintest whisper, only audible at all at full volume on the pot and broadcasting device. For reference, without the isolator, that volume position would be too loud for comfortable listening.
I can find no other mention of anyone experiencing this issue. All I can find is advocates of the isolator as a great solution to eliminating ground-loop interference, but no-one seems to have hit the problem that I have, as far as I can tell.
Attached is a sketch of the circuit, apologies if it is hard to read, i'm quite new to all this, and also the program it was created with, which is great but not so user friendly
Anyway, Hopefully one of the great minds amongst yourselves will identify some foolish error in my ways, and be kind enough to let me know about it.
If any further info is needed then please let me know
Thanks,
Invisigram
Thanks,
Invisigram
